Some sensor
Hi all,
I am working on a project that includes alot of sensors and other stuff and for documentation im using Fritzing. Which works like a charm btw :-)
So i looking for the following parts:
* PING))) Ultrasonic Sensor (http://www.parallax.com/tabid/768/ProductID/92/Default.aspx)
> >* Piezo sensor (not the speaker!) (http://www.lineasblancas.com/imagenes/Piezo_electricosWeb.jpg)
>* Bright leds and all the stuff involed to hook these up to a Arduino (i dont know what because im working on that... Sorry) (http://www.whalemedical.com/p/led1.jpg)
>And i had an idea that might be usefull...
How about a Arduino emulator, so you can test the schematics. Or another way to test if the wiring is save to hook up to your computer. And give an error of why it isnt correct. And how about a built in resisitor value calculator?
Thanks guys, keep up the good work because this is the way to go for people like me that dont know squat about electronics :-)
Hi Metalmini,
If by "arduino emulator" you mean "simulate the circuit", see the answer in our FAQ http://fritzing.org/faq/. By resistor calculator do you mean colors-to-ohms? Effectively, Fritzing already does ohms-to-colors.
Cheers,
- j
Post a Reply
Please login to post a reply.
