moving everything
gijs gieskes 8 years, 9 months ago
when i move the pcb in pcb vieuw, and then press undo. the trase get all mangled up.
this is anoying because i often exidentaly move the pcb..
Jonathan Cohen 8 years, 9 months ago
Hi Gijs,
So far I haven't been able to replicate this bug.  Can you email your sketch file (or shareable sketch file, if you're using custom parts) to info (at) fritzing (dot) org and I'll take a look.
Thanks.
- j
Hi J
i have not saved the file.. already deleted it. But i have had this many times already, so i will see if i can make a file for you.
greets G
ticking 8 years, 8 months ago
I have the same problem on os x.
And another that arises from the first one.
When you enable align to grid, and use a custom pcb size, that is not a multiple of the grid size, and then move the pcb, the board will be aligned to the new coordinates, broblem is, the parts on it, won't. So everytime you move a wire from then on it wont get nice 90° and 45° bends and so on.
Jonathan Cohen 8 years, 8 months ago
Hi Ticking,
It would help us debug this problem if you could send us a sketch that has the buggy moving behavior.  Email it to info (at) fritzing (dot) org.   If it has the custom-size board making the wires go wrong, that would help too.   If it also has custom parts, please do "save as shareable..." and send us the resulting fzz file.
Thanks.
- j
Jonathan Cohen 8 years, 7 months ago
The mangled-traces-after-undo bug will be fixed in the next release.
- j
