jumper component not rotatable (PCB)
I would like to place a jumper (vertically) but I'm not able to rotate it (button is desactivated). Is this normal ?
Thx
Posted 1 month, 3 weeks ago by kumy
Yes, this is normal, in the sense of "not yet implemented".
For now, you can move each end of the jumper item independently to where you want it to be.  When you hover the mouse over one of the connectors on the jumper item, you will notice that the circular highlight area extends around the central connector area.  You can grab that outer highlight region and use it to reposition that end of the jumper item.
- j
Posted 1 month, 3 weeks ago by Jonathan Cohen
Thanks for the tip ! I've already tried that, but not enough precise as a new wire appears... Augmenting zoom factor let me handle correctly the circular highlight.
Post a Reply
Please login to post a reply.
© 2007 - 2010 University of Applied Sciences Potsdam
