please add resistor 0 ohm
could you please add the value 0 ohm in the resistors values.
0 ohm are usefull for multiple reasons: (for exemple):
* avoid using a strap (difficult to handle ; more protection of conductors ; ...)
* anticipate using a "real" resistor (with a "real" value) in the furture.
* production facilities...
* maybe others...
Cheers
Posted 1 year, 6 months ago by kumy
Not sure whether you wanted something different, but if you select a resistor and look at the display in the Inspector, there is a "resistance" popup that will let you change the value to zero--it's not on the preselected popup list, but you can just type it in directly.  In breadboard view, the resistor's stripes will change accordingly.  I will add it to the preselects.
- j
Posted 1 year, 6 months ago by Jonathan Cohen
This is exactly what I need. I did not realised I could type it directly !
Thanks.
Hi, i saw that the resistance 0ohm gets added in the devel branch, but there is a minor issue:
As it is a 0ohm, the two legs should be "linked together" (at least in the PCB view, when hold down mouse button on an leg, the other should be highlighted in yellow).
Thanks, will add it to the issue tracker.
- j
Post a Reply
Please login to post a reply.
  • RSS
  • Atom
  • Print this
