flod fill
what would be nice is a flod fill (copper fill type of thing), where it would fill every part of the pcb (that is not used) with holes.
Posted 1 year, 5 months ago by gijs gieskes
Hi Gijs,
We actually have had this feature for a while now.  In the PCB view, just click on the "Trace" menu and select "Copper Fill".  Jonathan even made the fill feature smart enough that it tries to use the fill areas for ground planes.  There's also a corresponding "Remove Copper Fill" menu option that you'll probably want to use if you do more heavy editing of the PCB.
-Brendan
Posted 1 year, 5 months ago by Brendan Howell
hi Brendan
what i actualy ment was that it fills the area with holdes, holes that you can stick parts throu.
the idea is that this way every part of the pcb that is not used, can be used a prototyping area (-:
greets G
Post a Reply
Please login to post a reply.
  • RSS
  • Atom
  • Print this
