Screw terminal / Terminal Block (2EDG-3.81-2T) Pin Spacing 3.81mm Part
eduardofritzen 5 years, 7 months ago
how can i use 3.81mm Pin Spacing in Fritzing Screw terminal Part? I need to create a new part?
Part is "2EDG-3.81-2T" Terminal Block Connectors
Regards,
Eduardo
André Knörig 5 years, 7 months ago
André Knörig
Hi Eduardo,
You could use the pin header part instead. It offers a 3.81mm/0.15" pin spacing. Just make sure to give it a large enough hole size.
