Highlighted wire isn't focus in schematic view
tsyu 8 years ago
I'm working mainly in schematic mode. When you hover over a connection with multiple wires, each wire can be highlighted in blue (which wire depends where exactly your mouse hovers). If you click to move the wire, however, the wire that is moved is not necessarily the wire that was highlighted (sometimes it is, sometimes it isn't). I assume this behavior is unintended, correct?
Jonathan Cohen 8 years ago
Hi Tsyu,
Yep, it's a bug.  Thanks.
- j
tsyu 8 years ago
Thanks for the quick reply. Great software, by the way.
-Tony
