Inconsistency between schematic and PCB view
eallaud 4 years, 10 months ago
Hi all,
in the two screenshots you can see the inconsistency (version is Version 0.8.7 (b1bf5 2014-01-24)): on the PCB view the via from the IC (ATMEGA328) pins 19 goes to the JP6 header pin 6 the pin 18 goes to JP6 pin 5 and so on pin 15 goes to JP6 pin 2 and pin 11 to JP6 pin 1. If you at the schematic it's all mixed up.
Can someone confirm if its a bug or a feature ;-)
TIA
Bye
Manu
PCB View
Schematic view
Hmm looks like I messed up something when trying to attach the images, so here are the links:
PCB View: https://drive.google.com/file/d/0ByRuFC9U_9VhTzRVY0FwY2x1aHM/edit?usp=sharing
Schematic View: https://drive.google.com/file/d/0ByRuFC9U_9VhaG1JWjZOdVRxMzQ/edit?usp=sharing
Sorry...
Stese 4 years, 9 months ago
I'm seeing similar things between Breadboard and PCB View, version 0.9.0 x64. (I've created a post in How do I...)
