Potentiometer
JohnBunyan 4 years, 11 months ago
Tried the Ping Pong Matrix but the potentiometers will not fit into the breadboard. I didn't want to bend or cut off the 2 metal parts that prevent it going on the board. Any suggestions?
schnee huhn 4 years, 7 months ago
schnee huhn
uff..same problem here. did you found a resolution??
Markus1811 4 years, 7 months ago
the only solution i see is to bend the two metal parts away... that is what i did... i do not expect to use the parts from the creator kit in an production like environment in the future... i handle them as experimental parts. can send picture of the potentiometer if wanted ;-)
