Fritzing is does't RUN
Areecki 4 years, 4 months ago
Hello friends
I have a problem with running the program. After downloading and unpacking, and click on the exe gives me an error such as a picture ...  My system is XP SP 3. Please help me, whats it's wrong.
I am of Polish so excuse the spelling
http://scr.hu/0fqx/zyo32
Fabian Althaus 4 years, 4 months ago
hej Areecki,
what does the error message say? it seems to be some memory error. what kind of xp do you use? 64/32bit? what kind of fritzing version do you download? 32/64bit? have you tried both versions?
what happens if you download an older version?
I do not know what it says this error is a memory error?
Version Fritzing : http://scr.hu/0fqx/0s4xm
My Computer : http://areecki.ihq.pl/Report.htm
I donit tried both version, where I Can it download ?
I don't tried an older version too.
ok you have an 32bit os. try to download the 0.8.7b from the bottom of the downloadpage. did you get the same error? maybe it's a problem with xp and qt5. what does the older version?
http://fritzing.org/download/
I download verision 0.8.7b and it so don't work.
Errod code : http://scr.hu/0fqx/7ecxi
hej again,
the error-code is a critical error code. 0xc000001d. it can be caused from diffrent reseasons. maybe you have a bug in the microsoft net-framework or in the registry of your windows installation. please try a registry fixing tool. if that does not work please read this articel: http://errortools.com/windows/fix-0xc000001d-error/
i think the error occours because of your windows installation. do you have anything like microsoft visual studio installed? maybe you need to update it to a newer version.
i hope that helps. if not please sent your complet error log to my email adress: fabian (at) fritzing (dot) org
i do not know this program but it seems to be ok. i normally use "ccleaner" on my machine.
it's not bad to use a cleaner-program once in a while, because of the microsoft-ability to destroy itself ;)
let me know if that helps out.
I scan Free Windows Registry Repair http://scr.hu/0fqx/bpstr  - no help :(
I so have and use CCleaner http://scr.hu/0fqx/bzjg6 - no help ;(
http://scr.hu/0fqx/gddbg , http://scr.hu/0fqx/808w7 - I need update a new version ?
Total system Care it must by registry so I don't use this program, I need free program .
Maybe I use Combofix ?
