Unable to start Fritzing - missing library
I'd love to try fritzing, but I'm having problems getting it to run on Debian Etch. Here's the problem:
$ ./Fritzing ./Fritzing: error while loading shared libraries: libQtWebKit.so.4: cannot open shared object file: No such file or directory
If I check the dependant libraries, I see:
$ ldd Fritzing linux-gate.so.1 => (0xffffe000) libQtWebKit.so.4 => not found libQtSvg.so.4 => /usr/lib/libQtSvg.so.4 (0xb7f47000) libQtSql.so.4 => /usr/lib/libQtSql.so.4 (0xb7ea8000) libQtXml.so.4 => /usr/lib/libQtXml.so.4 (0xb7e64000) libQtGui.so.4 => /usr/lib/libQtGui.so.4 (0xb7795000) libQtNetwork.so.4 => /usr/lib/libQtNetwork.so.4 (0xb773a000) libQtCore.so.4 => /usr/lib/libQtCore.so.4 (0xb75ba000) libpthread.so.0 => /lib/libpthread.so.0 (0xb75a3000) libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb74b6000) libm.so.6 => /lib/libm.so.6 (0xb7491000) libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7484000) libc.so.6 => /lib/libc.so.6 (0xb734e000) libz.so.1 => /usr/lib/libz.so.1 (0xb7339000) libaudio.so.2 => /usr/lib/libaudio.so.2 (0xb7323000) libXt.so.6 => /usr/lib/libXt.so.6 (0xb72d4000) libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb72b1000) libSM.so.6 => /usr/lib/libSM.so.6 (0xb72a8000) libICE.so.6 => /usr/lib/libICE.so.6 (0xb728f000) libXrender.so.1 => /usr/lib/libXrender.so.1 (0xb7287000) libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0xb7281000) libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0xb727c000) libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0xb7273000) libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0xb7270000) libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7200000) libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0xb71d5000) libXext.so.6 => /usr/lib/libXext.so.6 (0xb71c7000) libX11.so.6 => /usr/lib/libX11.so.6 (0xb70db000) libdl.so.2 => /lib/libdl.so.2 (0xb70d7000) libpq.so.4 => /usr/lib/libpq.so.4 (0xb70b9000) libmysqlclient_r.so.15 => /usr/lib/libmysqlclient_r.so.15 (0xb6edd000) libsqlite.so.0 => /usr/lib/libsqlite.so.0 (0xb6e87000) libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0xb6dd7000) /lib/ld-linux.so.2 (0xb7f9f000) libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb6db6000) libXau.so.6 => /usr/lib/libXau.so.6 (0xb6db3000) libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xb6dae000) libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xb6d6f000) libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xb6c35000) libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb6ba6000) libcom_err.so.2 => /lib/libcom_err.so.2 (0xb6ba3000) libcrypt.so.1 => /lib/libcrypt.so.1 (0xb6b71000) libnsl.so.1 => /lib/libnsl.so.1 (0xb6b5a000) libpcre.so.3 => /usr/lib/libpcre.so.3 (0xb6b33000) libselinux.so.1 => /lib/libselinux.so.1 (0xb6b19000) libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb6af6000) libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb6aee000) libkeyutils.so.1 => /lib/libkeyutils.so.1 (0xb6aeb000) libresolv.so.2 => /lib/libresolv.so.2 (0xb6ad9000)
Clearly I need to get hold of libQtWebKit.so.4, but I can't figure out what package I need to install (ideally with apt).
Anyone out there with any experience on Debian?
Thanks in advance,
Lance.
Posted 2 years, 9 months ago by lwr20
Hi Lance, please, try running the sh script, instead of the binary itself:
$./Fritzing.sh
it should add the libraries that are included in the fritzing bundled that you downloaded, into your LD_LIBRARY_PATH
try it out and if you got into further problems, just let us know
saludos mariano
Posted 2 years, 9 months ago by Mariano Crowe
Thanks for getting back to me. I tried the script and get this instead:
$ ./Fritzing.sh /home/lwr20/install/fritzing.2009.04.02.linux.i386/./Fritzing: symbol lookup error: /home/lwr20/install/fritzing.2009.04.02.linux.i386/lib/sqldrivers/libqsqlite.so: undefined symbol: sqlite3_prepare16_v2
Not sure what this means. Perhaps I've got clashing libraries installed?
hi lance, it seems that your sqlite3 version is older than the one we used to compile the app, and does not provide the sqlite3_prepare16_v2() function (added on the 3.3.9 version, according to http://www.sqlite.org/cvstrac/wiki?p=WhenPreparedStatementExpire)
Can you do execute this lines?: $ sudo apt-get install sqlite3 $ sqlite3 sqlite3> select sqlite_version(); 3.6.10 sqlite3>
mine, for example, is the 3.6.10 (now you can remove the sqlite3 package if you want) and can you also provide your debian version?
thanks mariano
we have a hard time with the forum layout :) the commands are this:
$ sqlite3
3.6.10
sqlite3>
hi lance,
We've just tested the app in a brand new debian installation, an it works out of the box.
Just make sure to update your system, or install the package libsqlite3-0 >= 3.3.9
good luck!
mariano
Hi Mariano,
After running aptitude update, it seems that the latest version of sqlite3 in Debian Etch (current stable) is 3.3.8.
After a bit of Googling, it seems that someone has backported sqlite3 3.5.9-5 from Sid (unstable) to Etch. To get it, I added deb http://www.proesdorf.de/debian/ stable main contrib to my sources.list
After updating again and upgrading sqlite3 it now all works!
Thank you for your help, and I hope this thread helps someone else.
Lance.
Posted 2 years, 8 months ago by lwr20
Post a Reply
Please login to post a reply.
  • RSS
  • Atom
  • Print this
