processing - Nachtlicht mit fermata, Raspberry Pi und python
schlumpf 4 years, 8 months ago
Für den raspberrry Pi gibt es leider keine vorkompilierten processing Packete.
So habe ich das Nachtlicht mit Fermata und python nachgebaut.
Als erstes braucht man einige packete:
  • sudo apt-get install python-pip python-serial
  •  sudo pip install pyfirmata
Dann kann gestartet werden.
Zuerste ein kleines Testprogramm - zum testen der Verbindung und zum finden der passenden console:
"" This file is a basic program, testing if the firmata connection
   between Python and arduino works
   it assumes the RGB pins connected to pin 9, 10 and 11.
   And the Arduino serial Interface to be connected to '/dev/ttyACM0'
   If your setup is different you will need to adjust the variables at the start
   of the program.
from pyfirmata import Arduino, util
import time
# Module level constants
RED   = 'd:9:p'
GREEN = 'd:10:p'
BLUE  = 'd:11:p'
TTY   = '/dev/ttyACM0'
try:
  board = Arduino(TTY)
  pinRed = board.get_pin(RED)
  pinRed.write(1)
  print "rot"
  time.sleep(10);
  pinBlue = board.get_pin(BLUE)
  pinRed.write(0)
  pinBlue.write(1)
  print "blau"
  time.sleep(10);
except:
    print "Unexpected error:", sys.exc_info()[0]
    raise
finally:
    print "fertig"
Wenn das läuft auf zum fergesteuerten Nachtlicht:
""" This file is a basic program, testing if the firmata connection
   of the program.
import time
import sys
RED   = 'd:9:p'
GREEN = 'd:10:p'
BLUE  = 'd:11:p'
WAIT = 0.25
try:
    def loop():
        """ The worker function
    This function loops over and changes the colors or the LEDs
    The old Nightlight had 3 sweet spots keeping one color for a longer time.
    this version continously changes the Color Red->Blue->Green
    The speed can be adjusted with the WAIT constanct meassuring the time in seconds
    the current setting shall be lit. A full cycle takes 300 of these time units.
        # Red -> Blue
        for  i in range (0, 100):
            pinRed.write(0.01*(100-i))
            pinBlue.write(0.01*i)
            time.sleep(WAIT)
        # Blue -> Green
            pinBlue.write(0.01*(100-i))
            pinGreen.write(0.01*i)
            time.sleep(WAIT)
        # Green -> Red
            pinGreen.write(0.01*(100-i))
            pinRed.write(0.01*i)
            time.sleep(WAIT)
    if __name__ == '__main__':
        # connect the board
        # store the pins as variables
        pinGreen = board.get_pin(GREEN)
        # define a starting color - even though this is not neccessary
        # after setup all pins are off and red is the first color in the loop.
        pinRed.write(1)
        pinBlue.write(0)
        pinGreen.write(0)
        while True:
            loop()
except KeyboardInterrupt:
    print "Loop interrupted by keyboard"
    raise
except:
    raise
finally:
    print "fertig"
