Cannot change hole diameter if locale with decimal comma instead of decimal point
anadyn 5 years, 1 month ago
I encountered a problem with Fritzing 0.9.1, Windows 7 with Swedish locale (decimal comma):
It is not possible to change hole diameter or ring thickness under advanced settings to sizes with decimals when the locale is set to decimal comma instead of decimal point (standard for Swedish locale). Nothing is registered when the point key (.) is pressed. Comma is registered, but then the decimals are stripped so that 0,9 becomes 0 and 1,1 becomes 1. Very frustrating. After changing to decimal point in the Windows control panel and restarting Fritzing everything works fine!
Thanks for a great program,
Cheers Lars-Ove
