Install fail
JimWu 4 years, 1 month ago
this application failed to start because it could not find or load the qt platform plugin windows
win 7 pro.
fritzing 0.9.1.b. 32.pc
The_Doctor 4 years, 1 month ago
mines is failing too, but because QtPrintSupport.dill is missing
http://sourceforge.net/projects/fritzing.mirror/
I was able to install the program from this site
500amps 3 years, 11 months ago
It is probably not the zip file - it is more than likely the location of the extraction?
if Win 7  and it is in the C-Drive you need to run as administarator. Right click the friting.exe and select run as administrator and it should work. you do notice that the missing DLL is in the directory you are rumning it from.
I fell for same trap.
