Qt5PrintSupport.dill is missing. Why????
The_Doctor 4 years, 1 month ago
when i open fritzing for the first time, it works fine. After closing it and then reopening it, it says:
The program can't start because Qt5PrintSupport.dill is missing from your computer. Try reinstalling the program to fix this problem.
I did this and redownloaded the file but when i began extracting, my computer said it'll take 5 hours and something inutes to extract the file. I have no clue to whats going on
500amps 3 years, 12 months ago
extartct from Zip and then try right clicking on the fritzing.exe and select run as administrtor and it should fix problem as you should see the DLL file is in the extaracted folder.
extartct from Zip and then try right clicking on the fritzing.exe and select run as administrtor and it should fix problem as you should see the DLL file is in the extracted folder.
