Can't find the search box
RobertoOppeltFilho 3 years, 2 months ago
I've recently downloaded the new version of fritzing but i can't use the search tool because simply its not there.
i've seen others users in the same version and the search its there, and i have no clue what the problem is.
PS.:
I've try to download the previews version but no changes at all.
i try with 32 and 64 Bits versions.
RobertoOppeltFilho 3 years, 1 month ago
Someone please Help !
fmascarich 2 years, 10 months ago
Have you resolved this problem? I'm having the same issue, its just not there anymore.
I'm wondering if I clicked some shortcut to disable the search function?
This is the only post I've found with the same issue.
Fabian Althaus 2 years, 10 months ago
hej there,
this seems to be very odd. did you try to scroll down all the parts-bin symbols? maybe it is just at the end of the list? you can move the parts-bin symboles like you want.
do you try to close the parts bin? maybe if you reopen the bin-window it will have the "search" again. you can open it via: window -> parts
what system do you run?
Hi fa,
I'm running 64 bit windows 7. I didn't know you could move the parts-bin symbols around, but I'm still not finding the search option; its not at the end of the list or anywhere in the middle.
I've even tried older versions that I know worked, and theres still no search.
I tried closeing and re-opening the parts bin, stillno search. Finding parts by hand is impossible!
Top
Thanks for getting back to me!
ok, this is strange ...
please try to locate:
> '"User-Name"\AppData\Roaming\Fritzing' folder and try to rename/delete it.
(in this folder is all your user-parts and other changed stuff saved)
does this solve the problem?
YES! Thank You! The search returned at the bottom of the parts-bins!
Thank you!
good to know ;)
no problem, you are welcome
