Country incompatible shortcuts
dumle29 8 years, 5 months ago
Hi, first: Awesome program!
Then the problem, some shortcuts assume that you have a certain keyboard layout.
for example the ctrl + shift + [ isnt do able on a danish layout.
on a danish layout, youd need to do ctrl + alt + 8 to make a [ the same goes for ] its just 9 instead
just to clarify "[" and "]"
Jonathan Cohen 8 years, 5 months ago
Hi Dumle,
Thanks for pointing this out. One way to fix this would be for a volunteer to create a Fritzing translation file for Danish. More information about that can be found here.  We can also look into finding a different shortcut for that action.  (What does ctrl-shift-[ do, anyway?)
Cheers,
- j
