Wishlist - Top down view parts and "gradual" rotation
Fritzing is a fabulous tool for designing breadboard setups (I typically use Eagle for the schematic, move to a breadboard for testing, and finally create the board through Eagle.) Just two things would make Fritzing infinitely more useful for me: 1 - A true top down view of all parts. I know that this is not a design issue with Fritzing itself but of the parts used in the library. For example, the ICs, resistors and diodes work perfectly for a top down view. The e-caps, caps, transistors and regulators often lie over the board, obscuring potential wiring points. I know, I know - just draw them myself - but I battle to hold a pencil never mind draw! 2 - Currently, rotation can only be done in 90 degree increments but breadboard layout can often be much cleaner if we can rotate a component just slightly. For example, a crystal like that in the parts library can often be lined up perfectly with the two xtal pins on most microprocessors by placing it on the breadboard at an angle closer to 45 degrees rather than 0 or 90 degrees.
Otherwise, fantastic tool. Keep it up.
Regards
Steve
Posted 2 years, 6 months ago by swm1605
Hi Steve,
We're pleased you like Fritzing and thanks for your suggestions.
Adding free rotation to breadboard view seems possible; the hard part would be the UI. Would you be satisfied with 45 degree rotations, or do you require full free rotation?
As for top-down view, this has been an issue for Fritzing from the beginning, but the problem is that many parts do not read well from a top down view--it becomes very difficult to distinguish them.
What might be possible is to add another SVG to certain parts, and then have mode to switch between top view and 3/4 view. I like the idea of the mode switch being merely temporary (for example, by holding down a certain key you see the top-down view; releasing the key returns you to 3/4 view). But maybe it should simply be a preference setting that stays put until you change it. That all being said, I doubt we'd get to this feature in the near future.
  • j
Posted 2 years, 6 months ago by Jonathan Cohen
Hi Jonathon -
Thanks for the prompt reply. I used an unfortunate shorthand when describing the free rotation. The example I used with the crystal only really works if the angle is closer to 20 degrees than 45 degrees. So the short answer is really to have full free rotation, not constrained to an arbitrary incerement of degrees. As for the UI I would envisage grabbing the end of a component leg (perhaps with a keyboard modifier such as Alt, Shift or Ctrl) and dragging that point around until the component was angled correctly. Of course, being greedy, I still want the legs to snap to the breadboard tie-points!
As for the top-view / 3/4 view debate: Yes, there are some parts that would be less easy to recognise easily in a pure top down view (caps, e-caps, thermistors and tilt switches are the ones that spring to mind) but there are a couple of ways around that. The option I like best is to embed the schematic symbol for the component on the component so that the user gets immediate feedback as to the component selected. (Makes a great learning tool too - for many components there is little correlation between the schematic symbol and the actual component.)
The current component set is a mix of pure top-down and 3/4 views - again beign greedy I would really want a 3/4 view and a top down view for each component - that way I could toggle between a full top-down view and a 3/4 view.
The mode switch idea is a good one - we both get our cake that way, although I would prefer it to be a user configurable option.
regards
Steve
i would also love free rotation!
greets Gijs
Posted 2 years ago by gijs gieskes
I agree, rotation would be useful.  Like when using resistors, you could use them as you would use a wire.
BTW I'm new here.
Posted 1 year, 10 months ago by sciguy
The idea of a modifier key to activate draggin one leg only and snapping to pionts not bad.
Maybe the rotation should be kept as separate functionality? So one option is rotating the entire component, another is to drag one leg or the entire component.
Though, in the software it is working well without the modifier key. You simply drag the entire component by beginning the drag in the middle of the component or, begin the drag at one end/leg to move that leg. The rest of the component then rotates accordingly.
Posted 1 year, 10 months ago by carlox
I want to seconds that. Rotation would be great.
Personally right now all i need it 45 degrees but free rotation would be even better.
Great work guys and girls.
Posted 1 year, 8 months ago by stephan schulz
45 degree rotation is coming in the next release.  Free rotation will have to wait longer because it's a challenge to implement a mouse-based UI that feels good.
- j
Posted 1 year, 8 months ago by Jonathan Cohen
Post a Reply
Please login to post a reply.
  • RSS
  • Atom
  • Print this
