control a 7 sement display using an infrared remote control.
In this project you will learn how to setup and use an IR sensor and remote. some of th code may need to be edited depending on what ir remote you have. this can be done by opening the serial monitor and seeing what values are shown when buttons are pressed. you the replace the 8 digit code results.value is equal to in the if statments with the new codes you get from the seial monitor.
parts list
  • 12 x solderless wires
  • 1 x 220ohm resisters
  • 1 x IR recever
  • 1 x 7 segment display
Niccidaly22 4 years, 5 months ago
Hi i want to make one of these how do you set up the controller to the led? Is there any step by step guide for this project?
