Control stepper with directional buttons using a4988 Pololu driver.
I can't take any credit for this project with the exception of making it available to all of you. I searched the web for hours to find a combination of things what would work the way I need them to. This is the end results to get a skate wheel to turn when the corresponding direction button is pushed.
Things you will need:
Arduino Uno or Mega (probably other Arduino's but I'm not sure which).
Adafruit Protoshield or breadboard.
Various connectors to connect power and motor.
Stepper Motor (https://www.pololu.com/product/1200/specs) Mine is a six wire bipolar but I don't use the center taps.
Skate Wheel (https://www.pololu.com/product/3272)
Skate Wheel Adapter (https://www.pololu.com/product/2673)
Stepper Driver (https://www.pololu.com/product/2128)
and a power supply that has enough power to power your motor and Adruino.
XMTR 2 years ago
I found the code, sorry, it is possible to increase the speed of rotation?
XMTR 2 years ago
Can you provide the code? THX
sunza61 2 years, 9 months ago
goog
