Aurdino Radar BAsed On Ultrasonic sensor HC-SR04
Step 1:-Prepare Your Working Environment
Collect Materials
1.Aurdino UNO
2.Ultrasonic Sensor(HC-SR04)
3.Servo Motor 9g
4.Breadboard
5.Piezo Buzzer(You Can Add A relay Here Instead Of Piezo Buzzer for Setting Of Something)
6.Couple of Jumper Wires
Step2:-Follow The Diagram And Firmly Connect All The Components
Ul Trigger On D3
Ul Echo On D2
servo pin D9
Buzzer Toggle D4
Step3:
Upload The Code To Aurdino Board using Aurdino IDE Then-Open The Processing Download The Code I provided Dont forget To Change the com Port That you USe
Step4-Test The Gimmick
connect the aurdino to your Pc Open Processing Run The Code You Can See the Visualised Data From The Sensor
If Error Occurs Change the Screen Resolution In The Processing Code Or Change The Com Port I use Com3
fire ait and Rectify any Issues
step4:-Neat and Tidy
Enclose Your Project into some Boxes Or jar (Use creativity/imagination Here)
(I Used A Ice Cream Jar And Painted With Black Glued aurdino And Breadboard Using Hot Glue Gun to Inside of it And Connected Aurdino With External Switch and Battery)
Need Help Email ME Or Post a comment
6766sankar@gmail.com
vyasomkar 7 months, 1 week ago
What more modifications can we make in this project ?
