No projects found for tag 'temp sensor humidity sens'. Showing all projects instead.
Bluetooth Garage Door Opener
Add a bluetooth controller to your garage door so you can open it from any Android phone (using the android app).
1. Build this circuit.
2. Connect it to your garage door momentary switch via the output of the relay.
3. Download the android app.
4. pair your device with your bluetooth module
5. open and close your garage door with your phone
