Composite Sync Stripper
Cleans a Composite-Video-Signal and returns Csync
Devices like professional broadcast-monitors, crt-projectors or Extron RGB-Interfaces require pure Csync on their sync-inputs. If your source only outputs composite video instead of composite sync you can use this circuit to strip the video signal and receive pure csync.
2 x 0.1uf Capacitors
1 x 680k Resistor
1 x LM1881n
Requires 5-12V to operate
