This project shows how to connect, controland read an 4 wire computerfan,
INTRODUCTION.
This is the first one of several little projects that i
intend to upload, they explain the working of usual
or undocumented parts that i experimented with.
To power the fan you need an external powersource, in this case i used a 12 volt 1,5Amp DC Adapter.
But any other source that meet the requierements ofthe fan wil do.
Hardware:
  Arduino UNO-R3
  External powersource 12volt DC 1,5 Amp
  Potentiometer 1 KOhm.
  4 wire fan
Wiring:
The wiring colorcode for fan i used is as follows.
      Nidec TA350DC  Nidec TA450DC
+ 12 volt  Red                      Red
- 12 volt   Black                    Black
PWM       yellow                  White
Sensor    Blue                     Blue
Make sure that -12volt eg Gnd is connected to the Arduino Gnd.
Libraries.
No aditional libraries are needed.
Output:
The output of the code is just on the serial port.
So after flashing, open the serial monitor for
reading the values.
Potentiometer:
The potentiometer can easely be replaced by any sensor, as long as the output on the PWM port is converted to 0 to 255.
For example with an Temp. sensor you can control the cooling of your tablefan, or the cooling of your campervan fridge.
Good Luck, Jay
wwendorf 2 years, 2 months ago
You also had 12v for the fan doubling back into the arduino board, which just cost me an arduino board because it fried itself.
factotumindustries 2 years, 8 months ago
Turns out my fan was very particular and needed 25kHz - others I have tried are OK. Note your code documentation refers to pin A3 which is incorrect - you mean (digital in / out) pin 3.
This project will *read* a fan but won't control it. You have the PWM input of the fan connected to an analog output which won't do anything. PWM fans need a 25kHz PWM control signal...
