Connect Nokia 5110 LCD module to Arduino using + 2 zener diode + 2 47 Ohm resistor + 1 potentionmeter + 1 Nokia 5110 LCD module
Connect Nokia 5110 LCD module to Arduino using: + 2 zener diode + 2 47 Ohm resistor + 1 potentionmeter + 1 Nokia 5110 LCD module
From left to right: RESET, CE, DC, Din, CLK, Vcc, BL, Gnd
(breadboard view only)
AMI72 5 years ago
Hi Potok, I did checked the Fritzing libary, and I can not find the Nokia 5110 display. Could you please help? Thanks Andreas
AMI72 5 years ago
Ok, thank you for the information
potok 5 years ago
In software you have already model. Pinout is different, but if you connect it with this tutorial it will work
AMI72 5 years ago
Potok, that is a tutorial, how to work with the hardware. I want to use the display in the Fritzing software. BR Andreas
potok 5 years ago
https://learn.adafruit.com/nokia-5110-3310-monochrome-lcd
AMI72 5 years ago
Potok, I am asking regarding the virtual part within Fritzing. Not the hardware. Br andreas
potok 5 years ago
I bought it on banggood.com what I found they are cheapiest of all...
AMI72 5 years ago
Where do I get the LCD 5110 from within Fritzing? BR Andreas
potok 5 years, 2 months ago
Hello, Thanks for your work, I looked at your display, and found that pins are different (display has different pins names) But I ordered same display as you wrote. Can I still use your sketch?
eduardofritzen 5 years, 7 months ago
Hi, when i apply DRC, some warnings was showing: "Connector XXX on Part 'Nokia 5110 LCD Module1' should have both copper top and bottom layers, but the svg only specifies one layer.". Can you help to solve this warning? Thanks.
