The ESP8266 OLED (I2C) using Arduino Code.
This project is a standalone OLED display using the I2C (two wire) protocol. The cool thing is that it uses 100% ported ESP8266 Arduino code.
That means you can just dump the code in the ESP8266 with your Arduino IDE and voila! Working like a champ.
Imagine all the cool things you can stream to the screen!
Instructions:
1. After flashing code, solder ESP8266 pins to perfboard as usual.
2. Run a strip of solder across the back of the perfboard for ~3.6V and another for Common Ground.
3. Connect OLED SDA port to GPIO0 and SCL port to GPIO2.
4. Connect the Li-Po to VCC and common ground - and voila!
I couldn't find a fritzing model for the cheap OLED I bought from China for ~$4, but you can get them here: http://goo.gl/RRGMU9
viktor404 3 years, 1 month ago
Thank you for this, it works brilliantly! I have nodeMCU so had to connect like this: D3->SDA D4->SCL
WashJunior 3 years, 4 months ago
Thank you!!! I'm not using an ESP8266, but a MediaTek Labs Linkit ONE and by using only the I2C part of your code I was able to show something on the display.
pentiger 4 years ago
Hi, It's a nice piece of code. I am looking everywhere for a piece of code that would stream information from websites (weather info, stocks, etc.) but I cannot find how to do it. Could you post an example of how to do it? Thanks.
