MPX2010 Sensor with a LM324 setup as DC Instrumentation Amplifier.
I created a MPX2010 part and changed a TL074 quad Opamp to a LM124-324 part, the layout is the same but the TL074 part had some error. All needed files are included with this project. Hope that you find it useful.
sparky_08 3 years, 1 month ago
I needed your help...I have trying to build this project but I can't figure it that how much voltage did you use on pin 1 op-amp? wish u help
