NeoPixel driver using ATTINY85
This is a simple circuit for driving neoPixels with an ATTINY85 and 6-12v power source. Included in this design: 1.) 5v regulator with filtering capacitors 2.) IC Socket for an ATTINY85 chip 3.) pull-up resistor for an analog sensor (standard voltage divider setup) 4.) 2-pin input terminal for power (I'm using a 9v battery) 5.) 2-pin terminal for power switch 6.) 4-pin terminal for 3 or 4-pin NeoPixel product 7.) 2-pin terminal for analog sensor (i.e. a force-resist sensor)
Better Instructions coming soon!
