This is an hobbistic circuit, created with empiric method. We have a tollerance of 5% (tested with a Power meter)
Davide Caminati 3 years, 8 months ago
Davide Caminati
@dltccorreia: i know, this circuit must be in fase to read consistent value, but is tricky.
Davide Caminati
@kjag : stands for have a low Vref(not tipical 3.3V), so i've increase the sensibility for little currents.
kjag 3 years, 8 months ago
Hi Davide, please can you tell me, what the two 10kO Resistors are for? The one from MCP to Ground should be Pull Down. But what is the other doing? Greetings
Davide Caminati 4 years, 6 months ago
Davide Caminati
@dltccorreia i need to reassemble this circuit to give you more information, I'll do in a couple of days :)
dltccorreia 4 years, 8 months ago
Dear Davide, I've followed your project and I tested it myself, but I got inconclusive results. I used your code without make any change. The power values changes a lot ( I'm simulating the sct013 with a "singnals generator). Your help will be appreciated. Thanks in advance, Daniel
