Tilt Controlled Servo
A servo that is controlled by a tilt switch.
This is a tilt switch controlled servo motor. Materials Needed
-Arduino -Breadboard -Jumper Cables -Servo Motor -Tilt Switch -10k Resistor
Connect Using the Fritzing Diagram
Basic Idea is that when you tilt your breadboard, the servo motor will spin to a specified angle.
In the program, you can easily change the amount the motor turns. It doesn't have to be 90º all the time.
*code is included
