No projects found for tag 'temperature thermistor ar'. Showing all projects instead.
2 LEDs, 2 Push Buttons to turn them on and off when needed
push buttons must be held down to turn them on or off.
To build this I would use the following arduino code to play with it.
int led = 13; // the pin that the LED1 is attached to
int led2 = 9; // the pin that the LED2 is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup() {
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
analogWrite(led2, brightness*-1);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 10 milliseconds to see the dimming effect
delay(10);
