No projects found for tag 'ldr photorésistance capte'. Showing all projects instead.
3 pins to connect LCD 1602 to Arduino Less wires
Use only 3 pins to connect LCD 1602 to Arduino Uno
Every detail of how to connect your LCD 1602 using only 3 pins to Arduino Uno are show in the schematic. A simple code is attached and libraries. It works perfect.
To connect the LCD 1602 to the breadboard first you need to solder some Pin Headers to it.
Components:
LCD 1602
10K Potentiometer
PN2222A or BC547 NPN
74HC595 Shift Register
Breadboard
Male-Male Jumper Wires
If you can improve this project let me know, so I can made changes.
Thanks.
