5 and 3,3V power line for sensors
This is a very small platine with which you can provide 5 and 3,3v out of 5 volts current for your sensors.
This is a very small platine (8 columns by 6 rows on a standard stripboard) with which you can provide 5 and 3,3 volt power supply for your sensors. It is driven with 5v, provided through standard screw terminal, and provides you with 6 x GND, 6 x 5v and 6 x 3,3v.
It features an on/off switch and also a red LED to indicate operation.
The purpose of this little thingy is to provide easy access to ground and crrent for your sensors, in case you do not want or can't use a breadboard.
