A Dark Detector Circuit with npn Transistor
Components: -------------------- * npn Transistor 2N3904 * Resistance 100 kOhm * 5V DC Supply * LDR * Resistance 220 Ohm
Idea:
Control the LED ON/OFF using the npn Transistor.
Case (1): when there's light, the transistor will be in cutoff region,
and the LED will be OFF.
Case (2): when there's dark, the transistor will be in active region,
and the LED will be ON.
And the LDR will control the operation region of the transistor.
