No projects found for tag 'basic push buttons and le'. Showing all projects instead.
Advanced experiment- Arduino and WTV020SD-16P module
Add music/sound to your Arduino project
You can add music your Arduino project using WTV020SD-16P music module. The module works without Arduino also- CLICK HERE.
You can get all the details of this project on this page:
Arduino and WTV020SD experiment
OUTPUT: After you load AD4 format music files onto your 2GB micro SD card, you can select and play the loaded songs using SELECT and TRIGGER buttons.
Before you do this experiment, I recommend you to read the following tutorial: ABOUT WTV020SD-16P
