Analogue Thumb Stick to Digital Directional Pad Converter
A circuit that attmpts to convert the analogue voltage change of thumbstick to the 4 discreet digital outputs using LM239 Comparator IC.
The objective is to translate an analogue thumbstick to digital directional pad on a Gameboy Advance. Before connecting to the GBA, I'm trying to get the circuit to functiona as expected.
The thumbstick has two axis potemeters (an x and y axis). All up is 4.4v and all the way down is 2.5v. The LM239 is a 4 channel comparator that will translate the dip or spike in voltage from a given access into an "on" or "off" voltage across the 4 ourputs for the digital directional pad.
I can't get the circuit to function as expected. Best case scenario I can sort of get 2 out of the 4 pins to work. I'm pretty sure it's a ground issue and resistor setup issue (pin up pin down).
Here is a trace of voltage readings starting at the thumbstick down to the LM239 output.
Output of 3DS Slider
resting voltage is 2.5-2.4v
all the way up 4.2v
all the way down is .8v
Input of LM239
resting voltage is 2.5-2.4v on both pins
all the way up 4.1v on both pins
all the way down .7 on both pins
Output of LM239 (why isn't this passing .5-4.0v?)
Pin1, Pin2, Pins14, resting .4-.6v
Pin13 resting 2.6v
Pin13 all the way down .4v,
Pin13 all the way up 2.5v
Pin1, Pin2, Pins14, all the way down .1v
Pin1, Pin2, Pins14, all the way up .6v
