No projects found for tag 'controlapplicationbyttp22'. Showing all projects instead.
Angle and Distance Measurement Device using Arduino
This project demonstrates the interfacing of Accelerometer (ADXL335) with Arduino and calibrating it to measure Angle from a reference plane. Also measuring the distance from object in its line of sight. The sensor data is fed to Arduino (Analog Input), it is processed and then the values are displayed on and 16x2 LCD.
Required Components:
Arduino
ADXL335 Accelerometer
HCSR04 Ultrasonic Module
16x2 LCD
Pushbutton
10 kOhm Potentiometer
