Annoy-A-Toy
A toy that simply beeps randomly. Hide it and drive someone nuts!
This is a simple project that is easily built on a half breadboard. I did the programming with a cheap USBasp programmer ordered from aliexpress. There are several guides on the internet describing how to program the ATTiny85 with a USBasp programmer, just do a google search on usbasp attiny85. My tool chain includes gedit and avrdude. I learned most of what I needed to know to set this up in "Make: AVR Programming" by Elliott Williams (mostly chapter 2). That book focuses on the ATMega328P (the same chip used on the Arduino), but is easily adapted to use the ATTiny85. I highly recommend that book if you're ready to take the next step; from programming in the Arduino environment into programming micro controllers directly.
Parts List
ATTiny85
Piezo buzzer, passive
9v battery
9v battery snap
terminal block
5V voltage regulator
1uf capacitor
100uf capacitor
LED, red
LED, yellow
NPN transistor
push button switch
2 330ohm resistors
wire
half breadboard
usbasp programmer
The simple program and makefile are attached.
