Arduino 7 Segment dice
in this project you can make a set of dice using 2 7 segment displays.
in this project you will build a set of dice using 2 7 segment displays. you will be able to deside if you want to role one or 2 dice using a switch and a button to activate the digital dice.
parts list
- 22 x solderlass wires
- 4 x 220ohm resisters
- 2 x 7 segment displays
- 1 x toggle switch
- 1 x button
