Arduino and BA6209
I Could not find any good wiring tutorial for Arduino and BA6209, which is a motor driver, so I made my own.
Tutorial on BA6290 wiring with Arduino
The datasheet states that you need to connect capacitors to the IC, but they are just to prevent a failure when both Arduino pins are powered. I decided not to use capacitors, and rather make sure that, within my program, I do not make any mistakes.
Here is a brief explanation on the wiring:
CI PIN 1 -> Ground.
CI PIN 2 -> Motor.
CI PIN 5 -> Arduino Pin sending Forward signal.
CI PIN 6 -> Arduino Pin sending Reverse signal.
CI PIN 7 -> 5V in the Arduino.
CI PIN 8 -> 5V in the Arduino.
CI PIN 10 -> Motor.
If Arduino´s 5Volts are not enough for your motor, connect PIN 7 and 8 to an alternate power source, and connect all Grounds (including Arduino) together.
Example Code:
//Declare pins
int r = 10;
int f = 11;
void setup(){
//Initialize output pins
pinMode(r,OUTPUT);
pinMode(f,OUTPUT);
void loop(){
//Reverse
digitalWrite(r,HIGH);
digitalWrite(f,LOW);
delay(1000);
//Forward
digitalWrite(r,LOW);
digitalWrite(f,HIGH);
delay(1000);
