No projects found for tag 'sound modulator / control'. Showing all projects instead.
Arduino and MQ-2 (gas & smoke) sensor
Hooking up an MQ-2 (gas & smoke) sensor to an Arduino Uno via a breadboard
The wiring connection is important:
Both A pins and the left H pin need to be connected to 5V. Both B pins need to be connected to the analog input (A0). The right H pin needs to be connected to the ground (GND).
A load resistor from 2kOhm to 47kOhm needs to be connected to both the analog input and the ground. I am using a 22kOhm resistor here.
