AVR Single Digit Digital Dice "Guess the number"
Our digital dice will operate similar to that of a normal dice. When the button is pressed in the circuit below a roll will be simulated by displaying a sequence of number from 1- 6 then a number randomly obtained in the sequence would then be displayed on the seven segment display. This operation would repeat whenever the button is pressed.
Components Used:
- Atmel ATmega 16 Chip
- 7 Segment Display (CA or CC)
- Reset Button + 10k Resistor
- Pushbutton
- Power Source (5V)
- Wires
