Basic Experiment- Arduino and WTV020SD-16P module
Add music to your Arduino project
With WTV020SD-16P, you can add music to your Arduino project. Interestingly, the module works without Arduino also. You can check an experiment without Arduino- CLICK HERE In this project, you can play a set of AD4 music files with very simple Arduino sketch.
Simply connect your Arduino to WTV020SD-16P as shown on the Fritzing layout, download AD4 format music files(or create your own) and play music.
You will need a 2GB microSD card for this project. You can get more details of this project on the following links: a. About WTV020SD-16P b. Experiment 1 c. Experiment 2
