No projects found for tag 'wireless 2'. Showing all projects instead.
Beater I1
An easy 8-bit way to create standard beat loops!
Setting up the 8-bit counter HCF4017 with two possible connections, it is plausable to create beat loops, adjusting the velosity and the phase through the R1 & R2 that control the timing and duty cicle of the 555 timer.
Caution
Do NOT exceed 9V of power supply! It may harm speaker <8Ohms
