Breakout board for ESP8266 with DS18B20 temperature sensor
Stripboard based breakout board for ESP8266 with DS18B20 temperature sensor
I've created this stripboard based breakout board for the ESP8266 with a DS18B20 temperature sensor to have a solid basis for a WiFi connected sensor. The board also contains a button for reset and starting in firmware update mode. To make it easy to connect my Raspberry Pi to the UART (Serial) connection I've provided an extra pin header. The ESP8266 is also connected via a pin header.
Unfortunately for a stripboard the screw terminal is not correctly adjusted when the pin spacing is changed to 0.2in. It is a known bug filed at as Issue 2102.
