Brewpi Shield with LCD on Ardunio photo board
not finished yet so don't know it it will actuall work as configured
This design is a scaled back version of Daytripprs brewpi with LCD, you should only use it if you can't get hold of the boards Daytrippr is using, or like me you go through so many you need to find a cheaper alternative.
As of 27/2/15 it's not been tested but this model is based on the arduino protoboard and not the sainsmart arduino protoboard v6 as used by Daytrippr so required some rejigging to get things to fit, the reason i used this board is because i'm so poor at soldering this is my 3rd attempt and as these boards for me are much cheaper.
Not included on design:
- rotary encoder (i'd like to include this later)
- bluetooth module
- relay bypass
*FOR INFO THE RESISTOR THAT LOOKS LIKE IT'S ON TOP OF THE SHIFT REGISTER IS ACTUALLY PLANNED TO GO UNDER THE BOARD BETWEEN 5V AND THE PIN.
