Cable Gun - Nerf to prop conversion
Uses shift registers to make LED chasers for panels of the Vulcan BF-50 Nerf gun, so that it looks like a gun Cable would use in the comics.
This project sets up LED chasers that can be hot glued into prop guns. I made this with 7 LEDs to chase down each side of the Vulcan BF-50 Nerf gun and the blue LEDs are for 2 additional panels that I will cut out with a drill or dremel. The Arduino and batteries can be stored in the BF-50 battery compartment that will no longer be used.
