Please login first.
Code Oscillator LED
Morse code practice that also has an LED that flashes with the tone
Simple project, easiest is to place parts onto breadboard just like in the image first. Then place jumper wires accordingly. Use whatever color you have available. The image shows a push button. For a straight key, remove the push button and wire the two posts of your straight key in place of the button.
