Continuous Servo Robo V2
A 'duino based Cardboard Robot which uses two continuous rotation servo motors for locomotion. Estimated build time: under 1hr.
Robots are awesome!
You can have your own built with off-the-shelf parts in under 1 hour with this wiring!
Ultrasonic-Distance-Sensing and Movement Decision-Making Code by Nicky Ringland (Ultrasonic Distance Sensing Code extends from Ultrasonic Ping example and public domain)
Motor Controller Code by Gregory Kielian and Chris Newton.
Cardboard chassis design by Gregory Kielian and friends: Many props Will and Jane Fujimoto for their input! I'd like to give a shout out to my students from the VVMS Afterschool Robotics Activity adding their own tweaks and improvements! Props to Nicky Ringland for work with chassis and placement of the Ultrasonic-Distance-Sensor!
