UART- Digital I/O control using serial port
Digital I/O control using serial port using arduino mega
This is a series of simple projects aimed at getting started with Arduino. This will cover most of the important peripherals of the Arduino starting from simple Digital I/Os and serial communication interfaces.
1:UART-Digital I/O control using serial port.
2:UART-Digital I/O control .
3:UART-Digtial thermometer.
4:UART-PIR sensor intruder detection.
Digital I/O control using serial port:
connect the led to pin 13 and power supply 5v and ground.
If the character 'a' is sent as a input display the led turns on and if the character 'b' is sent as a input display the led turns off .
